Odometer - Toyota Prius 2020
vladmiro
I recently purchased an imported Toyota Prius (2020 plate) from a dealer and noticed that the odometer isn't adding mileage to the total. When I check Trip A or Trip B, I see that the mileage is being added, but it's not reflecting in the total mileage. The dealer has mentioned that the car may need a software update. Can anyone explain what might be happening?
Thank you in advance for the help.
Might be, but I reckon there's some sort of hack plugged in to stop the odo counting up - They are easily available despite having no legal application... :fear:
Did they sell it to you with the same mileage quoted? If so I'd get some money off as it's likely done a lot more mileage than quoted!
CAN blockers can be used to stop mileage - would need the instrument cluster removing to check.
Hope you didn't pay too much as car may have astronomical mileage, they hide there miles very well.
My old 400,000 mile prius had less stone chips and wear inside than cars I've had in the past with 60,000 miles on them.
