Hi all I have a 2012 2.2 D4D manual eruo5 4x4 and i recently had error P062D for injector no1. I replaced injector 1 and had no issues for 2,200 km but it threw the code up again yesterday however there was no misfire or judder or anything just put EML on, was going down hill under low load when this happened. Cleared codes and drove home about 80km no issues at all. Has anyone had experience with this before. Maybe there is a relay or fuse going bad. I checked all the wiring before i replaced the injector and did voltage test at connector for injector as well, continuity came back good as well. Any help much appreciated!
I'm having same problem p062d but still runs fine
