Recently bought an import mk2 Yaris, the display is in metric, is there a way to change it to imperial, have tried messing with the display buttons but can't seem to find any adjustment for the settings, can anyone help, tia
If it's a digital display, there is a strong chance you can't...
For some stupid reason, only the UK ones could switch between kph and mph - Even the Irish ones couldn't! Really daft since it's all electronic but that's what they went with.
Just in case, the procedure is to press the dash button (The one that resets the trip meters and also cycles through trip and odo) until the ODO shows, then press the same dash button and hold it down - If it supports different speed units it will cycle between mph and kph, dim and bright (IIRC).
If it doesn't it'll just cycle the display between dim and bright (I think!)
See also:
and
Possibly because a lot of UK vehicles drive on the continent, but maybe not so much the other way round?
