BD2 Battery Monitor Readings
dannyboy413
I have one of these bluetooth devices fitted to the 12v Battery in the engine compartment.  I have just checked the readings and it is showing '87%', '12.53v' and 'Battery OK'. The 12.53v is, I presume, the Battery state of charge (?) and the 'Battery OK' is rather self-explanatory. What exactly does the '87%' signify? The reason I ask is that sometimes this percentage figure can be a lot lower, e.g. 55% and is showing in red, even though I have the first 'Power Alarm' set to 50% in the settings menu. Can anybody shed some light on this please?
My Battery is showing 75% or 12,44volts.
The voltage is now just under it 12.5 + volts that it droped down to during night time as I use solar charging during the day but days are becoming shorter and some days are dull all day but I am happy until the voltage goes below 12.3 volts then I look at my system again.
I have my power alarm set at 80% & 90% you can ajust this if you wish.
