Abs light was on so sensor was changed light went out immediately but when went out light came straight back on . Had a front wheel bearing fitted and still no luck . I want my wee car back on the road so any help would be appreciated
What codes does it have?
 No codes found
what scan tool was used not all scan tools can read the abs
Perform a flash test, link pins 4 and 13, turn the ignition, and count the flashes of the ABS light
