Hi, anyone help me? I bought a Toyota Aygo and just found out the horn is missing and I can't find the wire for the horn to fit a new one. Does anyone have any ideas where the wire might be, please. Really stressing me trying to find it 😅
The wire for the horn runs from the front of the radiator (where the horn is usually located), underneath LHS headlight, UP the passenger side front wheel arch liner into the fuse box.
To gain access, you'll need to remove the front bumper, jack the front passenger side up, remove the wheel and remove the wheel arch liner.
Are you sure? If it's like the horn on the Corolla it's easy to miss when you use it.
  • Haha 2
first off have you checked the fuse (10 amp) in the under-bonnet fuse box
or do you mean the horn is physically missing from the car
Any other problems like the airbag light being on?
