Type 2 EV Cable Stuck in Wall Mounted Toyota Charger
Car was charging fine until I received a message to sat that charging had been interrupted On examination of the charger no power and the RCD had tripped but will not reset
Managed to remove the cable from the car but the other end is stuck in the charger
Call out to Toyota and Engineer visit awaited Any suggestions as to how I can remove the ev cable from my we all charger please
I take it you have no power to the charger?
if that's the case you might be stuck till someone comes to sort you out
but if you have power on the app under chargers there is a part in there that lets you disconnect the cable from the wall charger
