My Toyota Avensis 2004 is getting wet.
tcsapo48
I have a Toyota Avensis 2004 1995cm3 D4D and its getting wet in every bigger storm arund the pedals. From the clutch just a little left. And if it rains around 1 day the carpet is really wet. If we wash the car it gets wet too. We try to figure out where is the problem but we can't find it anybody has any idea?
Check the seals around the windscreen, windows, and doors for any obvious signs of wear, gaps, or cracks.Use a hose to spray water over different sections of the car (starting with the windscreen and doors). Have someone sit inside to look where the water starts entering.
Inspect the drainage holes under the windscreen wipers and sunroof (if applicable) to make sure they are not clogged with leaves or dirt.Pull up the carpet in the affected area to see if there’s any rust or water damage that might indicate where the water is coming in.👍
We checked those things and the door seals and windows and windsreen seals seems fine but the one's that are on the roof of the car are looks a bit worn. We try to water it firstly just the top of the windshield than the side of the windshield but it not leaks so i dont't know what to do than
Hi, is one of the windscreen wiper arms loose at the fixing with the spindle that drives it? There are seals there too I think.
hope you find the leak.
peter
