I'd like to replace the side mirror turn signal lights on my Yaris Cross 2024. I've spent some time trying to find videos/instructions online, but they're all for older models where the rear side mirror cover is one piece and comes off quite easy. Not so for the 2024 model where there's a top and bottom part rear cover. I can easily remove the top rear cover after taking out the mirror, using a thin flat nose pliers and a plastic tool. However, currently no clue how to remove the bottom part, which is preventing me from taking out the turn signal light. I've added some pictures for clarity. If anyone can share how it's done, it would be much appreciated.
The turn signal unit itself unclips from the Shell. It takes a bit of force to unclip it and it's a bit weird how the new one clips back in. I did it on my previous Yaris but I can't remember exactly how I did it.
This was my broken one... (looking from the lens side - which was smashed by some charming person!)
  • Sad 1
IMG_20240929_082412.thumb.jpg.ec9f33b208f7a3607f97e46830bec8ff.jpgIMG_20240929_083449.thumb.jpg.f42eb651cb701188fbda1286ad9b866b.jpg
7 hours ago, CPN said:
The turn signal unit itself unclips from the shell. It takes a bit of force to unclip it and it's a bit weird how the new one clips back in. I did it on my previous Yaris but I can't remember exactly how I did it.
Hi you must remove two screws and then unclip lower part of the mirror but be gentle in the corner of led lamp.Good luck
Hmmm... I don't remember undoing any screws to get mine out... It was clip fitted top and bottom on mine...
