Y Cross - Steering Wheel Controls
RDur
2024 YC Excel - can anyone point me to detailed tutorials/guides for steering wheels buttons please. On UK vehicle the left hand side buttons controlling display and menu navigation. I'm stuck with 'settings' showing and can't get out of despite reading available guides etc
Push and hold left hand ok button until brackets appear around the settings notice then push up or down on the button until it says blank if you want it blank or any of the other options you like. Then press the back button just above and to the left ok button.
This is from memory so hopefully I haven’t missed anything.
I'll try it when it stops raining and re-post result - thank
Press and hold ok, then up and down to change centre display, press right and left arrows to switch to the main L/R display centre content then scrolling up and down within. Once in the displays (call them Left, centre and right) press and hold ok to select (tick) what you want to be selectable from within it when you scroll up and down (if you haven’t ticked something it will show as ‘blank’).
That’s from memory but shouldn’t be a million miles out….
Just don't try to get the TPMS pressures to stay where you put them!
