Hello,
I have a Yaris 2015. Unfortunately, the bulb under the fan knob has blown and I'd like to replace it.
Are there any guides/videos for removing the facias to get behind the knobs to replace the bulb please. What bulb do I need for re-installation?
Thanks,
Pop off the dash pad, start at the passenger door, the heater controls pop off the dash complete with the trim
Use a plastic trim tool
Hello,
What bulb do I need to replace the blown one with please?
Many thanks for the information. Is the bulb clear or coloured?
It's a clear bulb with either a green, red or amber cover - if you go led the world is your lobster the 3 dials use the same type
I'm not following. LEDS also are coloured so I presume the colour of an LED needs to be matched. So I need to fit the correct coloured LED?
Are you saying that if I use an LED more colours are available. I think this is what you are saying?
I presume, the stock bulb is clear or do I need to check?
the standard bulb is clear it has a slip-on cover to change its colour, these bulbs from the dealer are expensive
LEDs, choose any colour you like, they are more cost-effective too
