Oil pump air bleeding / CVT fluid change
Jurosik123
please advise.
I have a RAV4, MXAA52 / M20A-FKS engine with K120 CVT gearbox. The car has a start-stop system. The repair guide for CVT fluid change ( drain and fill )  says that I need to do an oil pump air bleeding after the fluid raplacement using Toyota's GTS scan tool. As I don't posses such a scan tool is the air bleeding possible with other scan tool, evtl. is there some workaround?
Thanks hor helping.
