Help i need to replace my ADT270R-AEFEYW Rear Bumper
Scrinja
hi all anyone got a dummies guide on how to replace the rear bumper on the Abovea link or something
Taken off for a repair and rattle can paint and ive forgot the way i removed it
TIA Guys
....What a dummy its all fitted up and the laquer is only on a for day so still abit soft ..rain tomorrow so im hoping to get it on by wednesday
Looks like you did a decent job!
Thamks Dude i used to do abit of painting before
Well finally had a bit of good weather and now all done and dusted at last
3 base coats
3 of laquer that needs a couple of weeks to harden off before mopping
Also want to put a big shout out to @flash22 whose help on fitting it all back together
was Invaluable so thanks flass22 for all the know how Bro
  • Like 4
For anyone who is interested in the replacement I did the following as i was on my own and didnt want any mishaps after fitting it all up or any paint damage
I got a large cardboard box to roughly get it into place....
Then put some paper towel / Rag over each side where it snaps into place around the back light body clips to avoid any mishap
I just found a couple of extended bolts 5 cm to pop into place where it bolts up
The rest was easy as no damaged was about to happen
Wiggle up close remove one side of the paper towels then the other snap ito place fit bolts clips etc and your done ....Hope that helps
Sorry no pics but you get the idea
