While driving my toyota corrola gsx 180i engine dies ,at this time i noticed the hazard lights wont work and the dash clock
is off .Other indicators like the Battery and engine lights are on ,if i crank the engine it turns over normally but wont fire.
After about 20 minutes the clock and the hazards lights  work and i can start the engine and drive for a while .All fuses checked and contacts cleaned but it still occurs .
Difficult to say which specific points to check without the correct wiring diagram, but do not forget to inspect earthing connections to the bodywork, particularly in areas where a problem may be getting provoked by heat or vibration such as inside the engine bay. These connections are just as important as the fuses and relays etc.
