T22 leaking oil
Jappie
Hello everyone,
Recently I bought a t22. I have driving it around 4500km. Two weeks ago a noticed the engine sounding like a diesel, I have a petrol engine, so I poped the hood and noticed nothing. Then I checked the oil level and the oil level was nowhere to be seen on the dipstick. So I went on to fill the oil and two weeks later the oil level again was down to almost nothing (a litle bit more then 1L). So I asked a buddy of mine what the problem could be. We saw burned oil on the heatshield of the exhaust manifold around the backside of the engine between the engine block and the valve cover. So we changed the valve cover gasket, the oil filter and the filled it up with oil (5w30). Since we changed the gasket i have driven about 400km and I checked the oil level and still the oil level was noticeable lower. Then I went to check if the oil was still leaking from the same place and still is leaking oil from the gasket. Also when we changed the oil and oil filter the oil was black, while i had filled up the oil the week prior. My question is: Does anybody know why my car uses so much oil? I have read on this forum that the 1zzfe block of the build year of my car are known to be verry generous with their oil consumtion.
Some info of my car:
Has driven 119Km, 1.8vvt-i, motorcode: ZZT221(E).
ps. sorry for my bad English, this is not my first language
Can you see any oil leaks? My 1zz-fe engine leaks oil through the chain tensioner o-ring. The back of the engine is always covered in oil.
If there is no visible oil leak than it is most likely the famous oil burning issue. I don't believe there is an easy solution for that, just the engine rebuild...
I can see an oil leak, I think it is still leaking trough the valve cover gasket. Thankyou for the reply
What's the mileage on the car?
