How to stop "no key detected" warning
Hi Everyone
When I recently bought my 2007 Rav4, the vendor didn't provide remote smart keys, just traditional keys (that I have found later to be referred to as "Valet" keys).  I have to locate a key next to the ignition button to start the engine.  During driving, I regularly get the "no key detected" warning, and if we stop and anyone opens a door, there is an audible beeping both internally and externally.
This hasn't been a big problem for me up to now - I've been more concerned to be happy with things like engine, clutch, gearbox, brakes, etc.
But now after a few weeks of use, this gets a bit annoying and wondered if it may be possible to disable the "no key detected" warning?
FYI, I spoke with the vendor who said he lost the smart keys.  I also visited the local Toyota dealership about getting a new smart key, and they just rolled their eyes and said it would be very expensive to re-seed the key code and, for an older car such as mine, probably not worth it.
As you can appreciate, this is not a major issue (the car is usable), but it's more of a convenience thing.
Any thoughts, tips or advice would be appreciated!
Hi Alistair,Since you're using a valet key, you're getting the no key detected warning. The valet key doesn’t have the proximity sensor that the smart key does, so the car keeps looking for the smart key’s signal and assumes it’s missing. Unfortunately, there’s no simple way to turn off this warning since the system relies on that signal.
That said, there are a few things you can try. First, it’s worth checking the owner's manual, just in case there’s an option to adjust or disable the warning. Some cars let you tweak certain settings, though it's a long shot for this particular issue.
If that doesn’t work, you could consider an auto locksmiths as they can reprogram a new smart key for less. It will still cost you, but it might be cheaper than going through the dealer and would fix the problem.
Another option is to look into aftermarket keyless entry and ignition systems. These systems replace the factory keyless setup and come with their own remotes. While it won’t be exactly like the original smart key, it’s a potential workaround that could give you similar convenience without the steep cost..👍
Hi Bob
Thanks for the comments and suggestions.
I couldn't find anything in my owners manual on disabling the warning, so I phoned a local auto locksmith - who said they weren't able to do anything and I should go to Toyota 😞
So, I'm currently exploring the aftermarket keyless entry/ignition systems suggestion, to see if that may be a suitable work around.
It might be worth trying something like Carista as if I remember correctly there is the option of turning off keyless start with some Toyota models. Hopefully turning that off would stop the key warnings too, but I've never tried that so can't confirm for certain.
On my 2012MY Avensis you could disable the keyless
I've had a quick look at Carista and can't see this feature mentioned but I'm sure there was a way of doing it. It may have been in Techstream where I saw it.
Hi Nick/Scott
Thanks for the advice.
On closer reading of my owners manual I did find (on page 491, in the customisation section) that:
So I'll contact my dealer and see if they can do this....
