Yaris 1.5 Hybrid E-CVT Lounge Won't Start After A/C Cleaning
fra94
Hi all,
I'm hoping someone can help me with a problem I'm having with my Yaris. Yesterday afternoon I cleaned the air conditioning filter and ducts with a dedicated product, carefully following all the instructions. The car worked fine until the evening.
This morning I found the wipers stuck halfway up the windshield (which is strange, as I had turned the car off normally the night before) and the side mirrors were left open. I had to use the key to open the door, and now it won't lock with the key fob either. The car is completely dead; I tried jump-starting it, but it won't turn on.
I noticed some liquid leaking on the dashboard under the radio; it's the same product I used to clean the A/C. So, it probably hasn't dried yet. Could this be the cause?
Any help would be greatly appreciated!
Thanks in advance!
3rd generation Yaris or 4th generation?
You might have flooded some electronics and drained your Battery, probably even more than that.
Using any foam or other aerosols for ac cleaning are absolutely no go for me.
