My windscreen washers, both front and rear have ceased to work - no sound from either pump motor.
In checking the fuse layout, I see that fuse no 6 in the drivers (RH) side fusebox, is the one to check.
However the descriptor states Fuse 6 : Front wipers and washers; Rear wipers and washers; Door lock control.
With exception of the washers, all other items are working normally. I have checked no blockage in the plastic tubing and no sediment in tank.
The lack of sound from the motor pumps indicates an electrical fault - but the fuse is good.
Any thoughts from this mix of owners and experts would be most welcome, as 'no washers' is a MOT fail. Yikes!
VVT-i CDX 5 door Auto petrol W reg UK June 2000
Many washers only have one pump - it's driven one way for front and the other for rear. So it may 'just' be the motor has died.
Thank you, I'd not thought of that - I'll see if I can reach underneath the tank to feel whether a 'two way pump' is the case, it would certainly explain all the symptoms.
disconnect the wiper plug from the pump, and check for 12v when the stalk is pulled/pushed to wash
2000 will be a Japan built yaris (JT VIN)
I would suspect the stalk is the issue (integrated relay)
84652-52040
Pump
85330-10290
2 wire, 2 outlet with check valves, the stalk swaps the polarity for front or rear
