Dpf removal for cleaning stickies please
Rav 4 fourth gen XA40 2.0 D4-d needing removal of the dpf for cleaning. It is blocked and in limp mode. I need to remove it for cleaning. As soon as you try to Clear the fault on Carista the code comes straight back which means it never gets close to a regen. Tried an aerosol cleaner inserted into the dpf port feeding the engine side of the differential pressure sensor but without any luck on this score. Also, is there anyone within a 20 mile radius of Frome with Techstream?. I am struggling to do coding adaption with Carista so looking for help.
