Location of interior fuse board on 2024 rav4 grsport phev
Hey guys, just a quick question, where is the fuse board located in the car?
I can see the one under the bonnet and the one in the boot, but I thought there was normally one under the steering wheel, but I have been unable to locate.
reason being am looking to hardwire a Dashcam.
thanks in advance.
reason being am looking to hardwire a dashcam.
thanks in advance.
Not sure but I included a link in a post on the full schematics a few weeks ago. Found on Reddit.
I presume it won’t be different to earlier non-GRS PHEV which is behind the glove box. Be warned, you need to be very flexible to get at it!
Found these in the manual, which seem to indicate there are indeed 3 lots of fuse boards, (the ones in bonnet and boot), with the interior indeed being under the glove compartment.
Buggered if I could see it mind 😂
Assuming it is the same as the Suzuki Across - which I am fairly sure it is - you have to take the glove box out and it can be seen then. You have to push the glove box from either side when it is open after disconnecting the strut. I do agree with nlee  it is difficult to see into it unless you are very flexible. I decided to use the 12volt socket and then carefully hide the wire behind the glove box and then through the door and windscreen trim. I wasn't too bothered about having the Dashcam on when parked but you maybe.
