03 Corolla - Cricket noise
RamonToyota
Hi everyone,
My last MOT failed because ‘Nearside Front Wheel bearing rough when rotated’ and the wheel bearing was replaced. Since then, time to time, a noise appears. It sounds like a cricket to me. The noise disappears if I use the break. I am concerned that the wheel bearing was not replaced correctly and the garage says that everything is fine. Any thoughts?
Thank you!
