Hello
I'm trying to find the maximum diameter space saver wheel that will fit under the car.
Does anyone know the maximum size diameter of a 17" space saver wheel including the tyre ?
There are a number of options
125 x 70 x 17
135 x 80 x 17
165 x 80 x 17
Hope this makes sense.
Alternatively, does anyone have a spare wheel fitted under the car and if so, what size is it ?
Many thanks
Thank you for the reply. I'd already looked at the Road Hero info and obtained their measurements. The problem is it does not guarantee their wheel would fit in an available spare wheel space.
I'd like to fit the largest possible diameter wheel and tyre and I should have been more clear in my initial post. What I'm trying to find out is the size of the availabe space under the car and hence, what size wheel would fit. I'm partially disabled, so I cannot get down to measure the space. I thought someone may already have a spare located under the car and would have the wheel/tyre size and would know whether it was a 'tight' fit in the space.
