Posted (edited)
I'm at the bottom of the learning curve with much of this subject and I appreciate your help.
Under ' How to Charge ' options I assume I select  ' Normal Battery progrm ' but do I select ' AGM ' option. I had no knowledge about the AGM Battery until 10 mins ago. I visited the Varta site and cannot trace my Battery, model number 345 LN1-MF. The car is a 2022 1.8 Corolla H/B and the battery is in the engine compartment.
Maybe the charger 'recognises' the battery type and selects AGM, huh ?
Edited by badlywornroy
Spelling error
That's a standard 'flooded' Battery, not an AGM.
22 minutes ago, yossarian247 said:
That's a standard 'flooded' battery, not an AGM.
Thanks Nick, how did you find out ? I couldn't find that Battery anywhere.
By taking the Battery out and shaking it 😉😂
OK, not quite shaking it, but my Corolla had that same part number Battery and when I removed it I noticed that if I tilted the Battery carefully from side to side I could hear it was clearly full of liquid electrolyte inside. If it had been an AGM that wouldn't have been the case.
45 minutes ago, yossarian247 said:
By taking the battery out and shaking it 😉😂
OK, not quite shaking it, but my Corolla had that same part number battery and when I removed it I noticed that if I tilted the battery carefully from side to side I could hear it was clearly full of liquid electrolyte inside. If it had been an AGM that wouldn't have been the case.
Wow! you took your Battery out to help answer my question 😇 Huge thanks, I would buy you a pint . . . but . . . 🤗
Just now, badlywornroy said:
Wow! you took your battery out to help answer my question 😇 Huge thanks, I would buy you a pint . . . but . . . 🤗
Not quite, I replaced the Battery on my Corolla a while ago with a slightly larger capacity one. I still have the old one in the garage 😊
1 hour ago, yossarian247 said:
Not quite, I replaced the battery on my Corolla a while ago with a slightly larger capacity one. I still have the old one in the garage 😊
OK, makes more sense 😆 you answered my question, so thanks again.
