Stiff gear changing
Willss
We have a 2017 1.8 petrol manual avensis.  About a month ago there was a driveshaft seal leak which was replaced under warranty.  Since then the gear changing has not been as smooth.  To the point now when it is cold first thing it is tricky to get into 2nd/3rd gears - fine when warmed up.
I'm going to ring the dealership tomorrow to query (get booked in) but wondered if anyone had any thoughts (from what I've read low or incorrect gearbox oil (I understand it was replaced) are the most likely culprits but any other possibilities)?
Thanks.
