Hello all! I would just like to know if any of you guys out there know when things such as spark plugs, timing belts, air filters, fuel filters power steering/brake fluids, etc should be changed (for a 2002 rav 4).
I read both the owners manual and the service manual from cover to cover but it does not say when these should be replaced.
Thanks in advance.
from top of my mind -
- timing belt is checked at 105,000km service, and it is replaced at 150,000km service
- air filter is changed every 30,000km
I could tell you the rest, but it really depends on your country - check with your local service center for correct specs, just call over the phone and ask
Ok and thanks for the advice
