High pressure sensor location
Bluemind
Hello,
Where can I find the High pressure sensor location? I can clearly see the High pressure fuel pump, but can't find the sensor, supposed to be in the left side from the pump, needs to replace the sensor.
Either the sensor has a problem or the wiring because there is always problem with it after rain. Pump was replaced already.
