T27 1,8 - what gearbox will fit?
Samuelkullen
Hello!
I have a 2009 Avensis 1,8 petrol 2ZR-FAE, 6 gear manual.
The gearbox is not well, it only works on gear 3 or 6. Kan be forced to work on 1 and R instead. No noice and drives very well when those gears are engaged.
1, Has anyone done a repair of a gearbox like this one?
2, My gearbox is called 30300-05070. It's not very easy to find in Sweden and is expensive. On slightly newer Avensis with the same engine a gearbox called 30300-05080 is most common. Does anyone know if they are interchangeable?
Best regards
Samuel
