Hello , my corolla 1.8 , 2020 , when i start up all dashboard including warning lights be on and engine not starting up , i just wandering is that V12 Battery
 Video included
thanks
You need to press the brake pedal and then push start button to start the car and set in ready mode.
I done that but is not start up , stay the same
Was your Battery dead? I had similar issue, after charging - it went away.
I going to get starter tomorrow and will try , just worried to be something else
Sounds like the 12v Battery is too low to start.
If the Battery was low or disconnected for any reason the car will not start with one press on brake and one push on start button. You need to keep foot on brake and repeat pushing start button.
Measure your 12v Battery voltage and recharge it. Try again after that and let us know.
As others have said, your 12v Battery needs charging.
