howzit guys
are there any small mods which will increase power without touching the motor <_< <_<
Hiya,
What's the motor in, MR2 or Corrolla?
Best starter mods would be an induction kit/cone filter on the throttle body with a cold air feed and a less restrictive exhaust. These are the nice cheap (relatively) mods, probably get 8ish BHP from them.
After that you can go to larger capacity injectors and/or chipping (just increases amount of fuel dumped in the engine).
The best way to get better performace though is to reduce the weight of the car.
Good place for info on the 4AGE is www.mr2oc.com
Welcome to the board. :D
HTH
Chris
