problem vsc
ygy
Hi, I have  auris 1.4 d4d 2008 year
188000km next service 197000
,when I turn on the ignition it says VSC on the board and the wrench is drawn, I turn it on and it goes away, the engine works normally and everything else is fine
and how can i delete it
If that is what I think it is, you can't. That's perfectly normal. It is supposed to be that way.
If there are no errors like "Check engine" or "Check VSC", and the display only shows "VSC OK", that is perfectly normal. That's just the pre-ignition check up.
I have the opposite... after replacing the lower control arms on my 2006 Avensis 2 D4D and the brake disc's and pads. My traction control light comes on along with the VSC dashboard light after driving for around 5 minutes. Both those lights come on when starting then go away when engine starts. I cannot switch off the traction lights from the switch. Once I switch the engines off they do not light up when starting until I drive for several mins.? Any ideas please? Oh as an afterthought I snapped the 10 mm bolt holding the ABS sensor but drilled and tapped it to replace it.
I don't know...  Badly installed ABS sensors? Maybe damaged ABS sensors when installing new brake discs and pads?
