Toyota Aygo ab10 Shaking at low speed
sbsBLU
Hello guys,
I am a little bit at the verge of insanity...
I had enorm problem with shaky engine (engine was Shaking but non of problems from below occured, after mainterance problem with shaky chasis begon) and that was quickly solved by replacing faulty engine mounts. Before changing them everything was "Perfect" besides engine dancing. After replacing engine mounts and gearbox mount I went for a test drive... Then problems eldorado just begon... When at low speed my Aygo chassis started Shaking but on higher speed and on neutral problem was gone.
I checked every possibility and replaced both axels (complete) with new CV joints, seals etc - both just shiny new. Stabilizer and whole breaks set was trash so i replaced that too.
Anyway, chassis shaking problem is still there, it is not that bad as it was before mainterance but still i can notice it.
P.s there was also missfire problem but new sparks and coils solved that issue.
Any ideas WTF is going on?
