Where is the switch on 2014 Estima to have courtesy lights come on when the door opens?
Hi Steve,The switch for the courtesy lights that turn on when the doors open is usually found near the interior light or on the overhead console.
Overhead Light Switch,the switch normally has three settings:
ON, Keeps the light on all the time.
OFF Turns the light off completely.
DOOR or AUTO, This setting makes the light come on when a door is opened. Make sure the switch is set to this position for the courtesy lights to work with the doors.If the light still doesn’t come on, check the small button switches on the door frame. If one of these is stuck or faulty, it might stop the lights from coming on.
If it still doesn’t work, you might want to check the fuse or the light bulb itself for any issues.👍
