2020 rav4 sat nav showing cameras but no audible warning,any ideas please?
Hi Charles,try going into the navigation settings if you have the Toyota Touch 2 system and make sure that speed camera alerts are enabled. The navigation volume is separate from the main audio. Turn it up while a prompt is playing to check if it’s muted or too low.
Check the navigation maps are current as they may need updating, its worth checking the Toyota Touch 2 system has the latest firmware .👍
Don't exceed the speed limit 😉
