Toyota Corolla G6R {abs rings}
Mark Robinson
I have a 1999 Corolla G6R. can anybody please  tell me what is the inner diameter and outer diameter and the width of the ABS Ring i need to fit my car.
i've been looking online.when i think i've found one i put in my Reg and it say not for your model..
Built - 12/1998
Model - AE111R-AGFNKW
Japanese built cars can have a lot of differences in the brakes and transmission compared to other markets
Rings are part of the CV they use the driveshaft numbers for reference
RH 43410-20452 (old number 43410-20451 )
LH 43420-20283 (old number 43420-20282 )
CV's are the easier option, changing rings can be a pita if you can find them (Toyota don't list the rings)
OK Thanks.. for your reply
Try Autodoc or onlinecarparts.  There are lots of other places who supply reluctors (ABS rings)  I would expect to pay no more that £15 for a new one.
They are the same company all part of the German car part mafia they often incorrectly cross-reference parts, as I said above Japanese built cars do use a lot of different parts compared to the UK/euro cars
rings are a pita to change as you need to get the old ones off then freeze the cv or heat the rings to fit them and hope they don't crack but that depends on what value you put on your time
I've always found that the old ones are a piece of cake to get off. Half the time they are split and can be taken off by hand.  If they're not split, they just tap off.
Putting the new ones on is just as simple, no freezing needed.  Just put them in a pot of boiling water for a minute and tap them into place with a rubber or leather mallet.
