Auris E180 Engine undercover replacement.
Johnel
It appears that when I purchased my Auris the engine undercover tray was missing, and I’d like to get it replaced.
I have seen some used ones on eBay (often looking a bit worse for wear!) plus some new ones which must be pattern parts from this seller. - https://www.ebay.co.uk/itm/305602649565
Also there have been some listings for lower left and right engine undercovers. So that begs some questions -
1) Is the engine undercover a standard one for all E180 models petrol/diesel/hybrid? (My car is a 2013 1.6 petrol sport automatic)
2) Are the left and right undercovers also required to go alongside the main one?
3) Some of the main undercovers I have seen advertised have had the numbers – 51441-0F021 on them, so is that the part number I should be looking for?
Thanks for any help you can offer.
51441-0F021 seems to match the 2 liter diesel from BMW... Not your engine. I guess it is a different part, like this one:
11212-0T080
To be sure, go here https://japan-parts.eu/
get your VIN number and do a search for the correct part for your engine.
Thanks for the link, Jose, but it appears that japan-parts do not list the whole cover which I need.
This advertiser has one that looks promising - but will it be the correct one - https://www.ebay.co.uk/itm/176270416585?msockid=1c959e13ca5d61cc220b8e98cb086048
All the covers from breakers seem to have some splitting or other damage, which is not surprising as the majority of vehicles will probably have had a front end impact. But I would really like a new or newish one plus knowing the part number suitable for my car.
All further help appreciated.
