Key / key battery problem.
///MAZI
My remote fob sometimes stops working, the little tabs that hold the key Battery inside the fob don't seem to hold the Battery securely enough.
If I open the fob up and push the Battery down then it starts working.
Any thoughts other than a new key?
Also any ideas on how much a key costs?
Keys can be from £30-60.  Keystation has OEM key that is over £400. Aliexpress and the other Chinese places do them as well for way less.
If the fob is working, then all you may need is a replacement shell which cost next to nothing.  You could try placing a small piece of foam or even a bit of folded card on top of the Battery, close up the Shell to see if that works.
