Correct gearbox oil for 6 speed 1.33
Fungus007
I've ready a few post here that the factory recommended oil to use is the  2.5 liters of SAE 75W GL-4 monograde full synthetic and putting in multi viscosity oil will cause long term damage.
However the only mono grade oil 75w gl-4 oil I could find is this brand called SWAG and doesn't indicate whether its full synthetic.
So my question is should I go with a know brand like Red Line MTL 75W80 GL-4 or Penrite 75w85 gl-4 full synthetic or the Swag brand?
Mt gearbox is also making a slight whirling sound at highspeed between 80/85km/h so maybe in my case having the multi grade thicker oil at normal operational temp is good?
ᐉ Трансмиссионное масло Swag 75W GL-4 1 л Желтый (10921829) • Купить в  Киеве, Украине • Лучшая цена в Эпицентр
The Safety sheet doesn't say if it's full synthetic - https://cdn.pkwteile.de/uploads/hazard/passports/2128211-EN-1.pdf
Autodoc does say it's compatible with the IQ - https://www.autodoc.co.uk/swag/2128211
The swag website swag.de doesn't say anything either.
Edited by Mark_P
added more to the post
