Reverse signal
etac
Hello, where can I find the signal to turn on the reversing lights in the trunk? On the power cable to the reversing light I have a strange 16V, so I'm looking for another place with this signal. A photo or diagram would be appreciated.
16v your meter must be duff (try a new Battery in it)
what do you want the reverse signal for ??
Im planning to install aftermarket parking sensors.
Worry because I used this, and system works only one day.
Do you know which color have this + signal, because all of them are varoious of white.
white with black stripe is ground, reverse is usually red
