I have just noticed that the yellow reversing lines have disappeared from the rear camera view.  Anyone know how they have gone and how do I get them back?
Hi Wendy,Check your infotainment menu to see if there’s an option to re-enable the guide lines, as they can sometimes be accidentally turned off.
 It could be worth asking your Toyota dealer if any software updates are available for the infotainment system. Sometimes these fix minor issues like this. As a last resort,you can disconnect and reconnect the car’s Battery to reset the electronics, though this might reset other settings in the car.
If these doesn't help, a visit to your Toyota dealer might be a good idea.They should have specific guidance for your model and might have seen this issue before.👍
When you go into reverse there are some icons at the bottom of the screen. One of those shows the yellow and blue guide lines
just tap to select.
  • Like 3
