Missing relays
rado77
Hi guys,
When I removed air conditionong module from center console (Corrola Hybrid 1.8), I found black bracket with 2 grey relays. I saw that on the left side there's missing one relay and on the right side are missing 3 relays. Do you know the purpose of these relays please? I don't know if cabling is connected to the sockets from back side, but PINs are visible. Please let me know. Thx, Rado
PS: by numbers on relays, should be these: https://www.franceauto.pl/pl/p/PRZEKAZNIK-CITROEN-PEUGEOT-TOYOTA-VFM-11F41-Z16-90080-87021/3701920241101_131950.heic20241101_131950.heic
20241101_131950.heic 20241101_130629.heic 20241101_130636.heic
2 on the left
Top - 12v outlet relay
Bottom - Foglight
Right side
Top left - Heated seats (ignition No.4)
Bottom left - Heated steering wheel
Top and bottom right - Heated seats front and rear
Ooo thank you very much ! :-) I thpught when I add them there, I autonatically activate "something" :-)  I also thought that maybe one of them will be for dead agle warning system and I simply change side mirrors with that function :-)  Guys at the dealer told me that adding this function isn't easy (maybe also ECU replacement) and it's very expensive. I thought that it could be easy - install wires do side mirrors, change mirrors, add some fuse or something and enable function in ECU...
