I swapped out the fuse for the washer fluid twice in two days. I'd put the first replacement down to a faulty fuse, but the second only lasted two 5km trips. Any ideas?
It's a 2020 Hybrid hatch on 102,000km/63,000 miles.
It'll still be in warranty won't it?
Take it to Toyota. Could be the pump.
I would suggest washer nozzles blocked or faulty pump.  Use a needle to clear the windscreen nozzles first as easy to check.
Three year warranty in Ireland, unfortunately. Pump is about a tenner so I'll grab one after weekend
Unless Ireland is different, you get a year's warranty with a service.
