Hi all,
I've just bought a Viofo A129 Plus dash cam set and have installed it myself by running the rear camera through the door seals, not through the headliner.
I've gone down the passengers side, but was just wondering if anyone else has had any issues with DAB interference?
Cheers
Fit a TDK 3-5mm clamp on ferrite on the dab aerial as close to the radio as possible
Sorry, not quite sure what you mean. Do you mean to the dash came cable or the aerial itself? It's a shark fin, so I assume you mean the interior cabling? If so, where would I find this?
Yes the dab aerial cable (black plug) as it plugs in it the back of the radio
Do you have a picture, by any chance?
pop the radio out - on the back you have black plug, this is the dab aerial, clip the ferrite on the cable, Job done
R7740632-01
Most dashcams nowadays have these fitted already!!
