Has anybody either experienced or found data that tell us how many miles you can travel in Hybrid mode when EV Battery is 100%, and also when EV range is zero and Hybrid kicks in (Battery at 20%) ??.
Then I assume you are the engine only.
I assume from the nature of your question that you have a PHEV? Your profile merely states GR Sport.
Range as a hybrid when you start with the traction Battery at 100% is about 550 miles.
Range as a hybrid when you start with the traction Battery at 0% (useable) is about 500 miles.
This assumes that you start with a full tank of petrol ... 😉
Range depends on how heavy your right foot is too….. there are so many variables when driving, the prediction above should only be taken as a very rough guide.
  • Like 3
OkThank you for your replies. Yes it's PHEV.
I think I worded it badly, I was not asking about total range, I meant Hybrid range only. I realise the cars total range is when the petrol runs out.
My PHEV went to the dealers for the  DC/DC converter recall and afterwards I found that my “home” dashboard screen was new, showing EV range + HV range as well as consumption figures in both EV and HV as well as instant consumption by accelerator pressure. A very useful guide to everything one needs to know for journey planning.
The PHEV is just a self-charging hybrid with a bigger Battery so that you have some true EV range - about 50 miles worth. After that, it's just a self-charging hybrid and, as such is reliant on having petrol in the tank. So, the answer is either zero or dependent upon the amount of fuel in the tank! 😉
Thank you, I did not realise it had the same self charging ability as a Hybrid version, which is good news to me.
Of course I know it has a self charging function which I have tested.
  • Confused 1
Range as a hybrid when you start with the traction battery at 100% is about 550 miles.
Range as a hybrid when you start with the traction battery at 0% (useable) is about 500 miles.
I'm at over 600.
