Hi to all,
i'm a proud owner of a Yaris XP130 that have a keyless start engine installed.
Is there a way to upgrade it to open also the doors?
I mean, the keyless control unit it is present. For sure i need a new handle door with a touch control. But i have no idea if it is enough or no.
Anyone as performed this upgrade?
Thanks in advance for your replay.
the locking part is very intergrated into the car's loom with 5 antennas
Thanks a lot. I've found on eBay 3 antennas, around 10/15 euros each. I'd like to check if the cables are present in my car (as -for example- the cables for courtesy lights).
Do you know if (and, of course,where) i can find an electric diagram or, better, an exploded view?
the car will not have the looms installed
it is an extremely complex system the aerials are just the tip of the iceberg, there are 5 total 2 in the front door handles (out side) 1 under the centre console, 1 inside the boot (trunk) and 1 more in the tailgate
I take it you have a keyed ignition with a start button
No, it's keyless. I use the key just to unlock the doors. After that i press the break pedal and i switch on the car by pressing the start button.
Sorry if i don't have understood your question.
so it has a keyless ignition thats half the battle as you will have the certification ECU and steering lock motor
xp130 smart key (entry).pdf
Thank you for the electric diagram!
The situation don't seem so bad at all.
I've "Just" to check the wiring that start from the ECU.
I think that, after the 5 aerials, i have to find if there is or no the "Doors control receivers".
Many Thanks
you have the door control receiver (that is part of the standard remote locking)
