Nearside rear tail light problem - MOT Tommorow.!
Shane1066
Changed bulb but no help - Numberplate light OK so is the nearside tail light on its own fuse and if so does anyone know where it is and what number.
Any help greatly appreciated as MOT tomorrow morning -. Italian import LHD 2008 Yaris 1.4 D4D Auto
both sides come off the same fuse check for 12v, 12v with a body ground and ground on the light to body ground
you can have issues with the loom plug that plugs into the light
Thanks, Bob, but that's a real downer as a fuse would have been a simple fix but finding an issue in the loom will be a nightmare as the earth on the bulb holder is also used by the indicator, brake light and reversing light all working absolutely fine so not a ground issue therefore it must be the live feed and no chance of finding that before the MOT in the morning.
