The left tail light and brake light work individually but both cut out when used together:
- when lights are off, the brake light works
- when lights are on the tail light works.
- when the lights are on AND I apply the brake both cut out.
Any ideas what’s going on and how to fix it? Many thanks.
Topic moved to the Yaris forum
Bad earth  ??
:withstupid:
poor ground on 1 or both lights, any water ingress into the boot ?
Very typical symptoms of a faulty earth to the cluster. Using the indicator may also produce an interesting display 🙂
Definitely earthing issues. Yu will find an earthing wire connected to the body near the tail lights. Undo, clean surface of retaining screw/bolt and body and refit
Remove both lights from the car and check for dirt, rust and moisture which there most likely will be.
Check the connections and remove the bulbs+bulbholders
After all this, did she pass?
Alex
