Screen Icons
WOODWAYS6
Hi what does BSM mean also.a broken vertical line with a view of a car from above at an angle with P A to the rh side ? All in green.
Read your manual
BSM - blind spot monitoring (flashy light in the wing mirrors when it senses a car in your blind spot)
LTA - Lane trace assist keeps you inside the lines if you drift the steering will pull you back in the lane
PA - park assist, if you have the intelligent park assist the car can park itself
46 minutes ago, flash22 said:
Read your manual
Ah thank you for that 👍
