OBD
Tony Birch
Where can I find the OBD on a Toyota Hiace Hilife GXS 2liter camper van ,Diesel year 2000
I would be grateful for any advice
my van will crank over but will not start,need to do a diagnostic,to see what’s going on.
Crank sensor would be my first port of call
2.0 diesel ?? - thought they were 2.4 or 2.5
iirc Obd2 port should be at the same level as the bonnet release, to the left of the steering wheel
diesels pre 2005 can be a pain as they are not 100% obd2 compliant and not all scan tools will talk to them
You may have to perform a flash test
link the 2 pins shown below, turn the ignition on and count the flashes on the dash
Thanks very much ,very helpful  and yes the van is 2.5
what do I do after counting flashes, what am I looking for
Edited by Tony Birch
Ask another question
count the flashes of the EML, it will be a 2 digit code 1st digit pause 2nd digit it will go onto the next code or repeat the code
post the codes on here
