OBD reader/scanner
Pete24
Hi does anyone have an obd scanner that will connect to the Proace? I have 2 and none will work, probs cos it’s a Peugeot in disguise
Any EOBD scanner should read the engine fault codes.
If you want to go more in depth your gonna need Diagbox.
You do have a working ignition key & the key in ignition warning beep when you open the door is working?
