Where about do the calipers slide pin go I got a 2023 corolla hybrid one of them in each side of front calipers got a ruber band I forgot what place they go
Lower pins has rubber bands.
Is that on all 4 of them ?
Not familiar with your later models brakes , but from what we have been told, with the disc rotating in a forwards motion the pin with the rubber is on the trailing edge of the caliper.
eg
Yea is a strange one i have changed the brakes and rotors as i made 50 k already on it is a 2023 corolla hybrid but im pretty sure one of the pins in left side was on top , the driver side was on the bootom I’m doubting my self and thinking maybe put both on the bottom
In our example shown above the offside wheels move in a clockwise direction when going fowwards, but on the nearside the move in an anticlockwise direction .
Check the location of the rubber pins on the rear calipers , they should follow the same positioning,
As far as I remember on Auris hybrid with larger brakes advics the rubber grommet is positioned on bottom pins both sides front R and L, where rears have grommets on top and bottom pins both sides L and R.
If wrongly fitted you may have some clicks when changing directions from forward to reverse and braking. That’s all. 👍
